AISC 360-16 Design results
Hello Team,
While using AISC 360-16 in STAAD Pro Connect edition Update 10 beam results show wrong failing criteria. for example a beam which is within allowable slenderness limit shows failure criteria as 'slenderness' whereas the unity ratio shown is for another design check clause. please advise a work around for this.
Parents Reply Children
