<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>RAM Connection - CS Round HSS End Plate Max thickness</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/234614/ram-connection---cs-round-hss-end-plate-max-thickness</link><description>Hey,
 I am using ram connection CS- HSS end plate column splice to design my splice with AISC code.
 In the geometry section, it limits thickness of end plates to maximum 1in. I wonder what&amp;#39;s the reason behind this.
 My column is PIP299x14. Plate</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: RAM Connection - CS Round HSS End Plate Max thickness</title><link>https://communities.bentley.com/thread/781223?ContentTypeID=1</link><pubDate>Sun, 10 Sep 2023 14:59:17 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:2d108c21-9b0c-4478-8d65-7a3015cbdc0d</guid><dc:creator>Dani Paul</dc:creator><description>&lt;p&gt;Hello Abhisek, i know this is an old thread but i noticed in the latest version of ram connection, that even though the description mentions as &amp;#39;End Plate Shear and Moment Connection&amp;#39; i see only &amp;#39;Axial&amp;#39; loads... so is it that the moments are resolved towards Axial forces (or) is that that the splice is checked only against Tension/Compression forces? please advise.&lt;a href="https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5932/Column-Splice.pdf"&gt;communities.bentley.com/.../Column-Splice.pdf&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: RAM Connection - CS Round HSS End Plate Max thickness</title><link>https://communities.bentley.com/thread/728732?ContentTypeID=1</link><pubDate>Mon, 29 Aug 2022 02:16:48 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3497e46e-b75a-4de4-b897-4500f56e764b</guid><dc:creator>Ang L</dc:creator><description>&lt;p&gt;Hey Abhisek, I had a hard time upload my cnx file. It allows me to input, but in the design result, it&amp;nbsp; shows warning, and&lt;img alt=" " src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5932/tpmax.PNG" /&gt;&lt;/p&gt;
&lt;p&gt;formula shows tpmax=1.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: RAM Connection - CS Round HSS End Plate Max thickness</title><link>https://communities.bentley.com/thread/728476?ContentTypeID=1</link><pubDate>Fri, 26 Aug 2022 05:54:59 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:385bc321-14d2-4bfe-9b35-7f3122840dd4</guid><dc:creator>Abhisek M</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;Can you please attach the connection file?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;I tried with the same configuration and can use plate thickness greater than 1inch. I tried with even 50mm and it is allowing me.&lt;/p&gt;
&lt;p&gt;&lt;img src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5932/pastedimage1661493316724v1.png" alt=" " /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
