Interaction Ratio in Base plate
Hello Team,
In RAM connection stand alone as well as the in-built connection design tab of STAAD Pro, the interaction check of anchors in base plate design considers maximum demands which are from different load combinations. Should the interaction check not be done for same load combination?
In the snip above, the demands are from different load combinations.
