Cannot Select Design Parameters Drop Down List
Hi!
I am a newbie user of STAAD PRO Connect Edition. I received from my senior some Staad Model that I need to review. It has 4 Design Parameters that checks different loading conditions and design checks. Unfortunate in the Post Process > Results Tab, I cannot select the Design Parameters Drop Down List as show in the image below.
What is the possible reason for this issue? I need to toggle between different parameters to view the different deflection and steel interaction ratio for each type of parameter.
Thank you!
Parents Reply Children
