Hello i came across this scenario,they say that there is a certain order of load cases which must be followed when creating the loadcases,may you help me with that sequence?
Static seismic load case must always be defined as the first load cases in the model. I am not aware of other sequence requirements in the load cases. If you question is specific to scenario, please provides some more details.
Answer Verified By: Joseph Lucas Magare
Thank you,i don't have a specific scenario i just saw a certain post one was getting error when performing analysis,then he was advised to start with seismic loadcase first.
