Simulation of piping loads when skid is om service.
Good evening dear community,
As you can see i study the behaviour of a crude oil skid when it is in service. In the first photo, you can see the skid as it is constructed in AUTOCAD PLANT 3D.
On the second one, I simulate loads of the piping with one vertical load (weight only when the pipe is full of product). On the 3d one I simulate the same piping loads but in 3 axes with the rule of thumb of friction load=0,4xvertical load and lateral load=0.1xvertical load.
The system is under the wind, seismic loads and their combinations as well.
After the model analysis and during the post-processing workflow, I see that with the vertical only loads, my model succeeds (4th photo) whereas, in the second scenario and 3-axis forces, a lot of beams are failing...(5th photo)
1st photo
2nd photo
3d photo
 (same situation with 3rd but support is isolated in order the view to be clearer regarding the 3-axis forces
4th photo
5th photo
Which option is the best to follow for better and more realistic results?  2nd option and 3-axis forces are over-engineering results?
Thank you very much in advance for your support!
Kind Regards,
