I have analyzed a structure and have got an error which say Above command is not recognized. please help me. i have attached my model as well. 2 STOREY RESIDENTIAL PROJECT.std
Move the line CHECK SOFT STORY ASCE7 before the line DEFINE UBC LOAD in the input file.
Also, PINNED supports makes this structure unstable, so you should change the supports to FIXED.
Please refer to the attached modified model. The support condition should be changed as you will get MY moment developed in the model. I have used one fixed support. Rigid diaphragm works for a floor-I have modified it.
1122.2 STOREY RESIDENTIAL PROJECT.std
Answer Verified By: Adrian
