Kindly refer to the model attached and reference pictures.
For FLOOR LOADS created under REFERENCE LOADS I am getting "WARNING- NO MEMBERS LOADED FOR A FLOOR LOAD GENERATION."
However, in the GUI the same panel is indicated as loaded for the load I am getting the warning for. I am getting a total of 14 warnings.
I don't know where I am mistaken.6011.Building 2.STD
You should not be using the exact coordinates in the Floor ranges. Instead, a minimum range should be slightly lower than the actual coordinate is and the maximum range should be a bit larger than the actual coordinate is. I.e.
I.e. if your X coordinates of the boundary are 6.78 and 11.304, then you should be using XRange with minimum value as 6.75 and maximum as 11.31.
Answer Verified By: ashish ashish
