It is indicated in the help manual of staad is that "set print stiffness" command to be used to know the stiffness of individual member stiffness.however when I applied this command before joint cooordinate it is not working and this vommand is not recognized by staad.
Please tell me how to use this command. A sample staad file wil be great help
This command is applicable only for the Basic Solver in STAAD.Pro. However, the Basic Solver was removed from STAAD.Pro a several release back, so the latest versions of STAAD.Pro are using the Advanced Solver only, which does not support the "set print stiffness" command.
