ERROR: MEMBER # 3 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10 - in Staad.pro
Hi Staad master sirs, I’m Trying with the Staad.pro model of a Rack system with Economic solutions - which consists of Hot Rolled Sections + Cold-Formed Steel sections, by using IS800 + IS801.
My entire members are only supposed to be Designed as Hot Rolled sections & Bracing members are Cold Formed sections.
Even After several efforts - I’m receiving lots of Errors
How to Fix these Errors. Help me...
NOTE: Torsion and deflections have not been considered in the design.
  _    STAAD SPACE                                              -- PAGE NO.   10
    ERROR: MEMBER #      4 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
    ERROR: MEMBER #      5 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
    ERROR: MEMBER #      6 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
    ERROR: MEMBER #      7 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
    ERROR: MEMBER #      8 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
    ERROR: MEMBER #      9 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
    ERROR: MEMBER #     10 IS NOT A VALID COLD-FORMED STEEL SECTION. E-10
                         STAAD.Pro CODE CHECKING - ( IS:801 )   v3.0
Steel_Design MY KN Done 1.std
Parents Reply Children
