I have trouble with opening STAAD. Pro Connect Edition, once I click the icon, it will show the launch page, then popup window appears as shown pictures:
once click "OK", the second popup window shown as:
I wonder how I can solve that problem.
Thanks.
Which STAAD.Pro are you using? The latest version is 22.11.00.156, so if you are not using this version yet, try to upgrade. If you are already using this version, then try a solution described here: STAAD.Pro CONNECT Edition has stopped working - RAM | STAAD | ADINA Wiki - RAM | STAAD | ADINA - Bentley Communities
