Hello Team,
WARNING:MEMBER- 113 is a slender section, design performed using unreduced profile.
Above warning message comes if i used SLF 1 command in design parameter.
this warning occurs if design code is AIJ 2005 member passing in utilisation but still this warning occur is it safe? or any issue of this warning
it is conservative,we can ignore this warning ? or i need to change the profile sizes?
Please Advise!
Thank you
This indicates the section you have selected is slender but during design program is not calculating the effective sections reducing from the original profile. Please see below snap from help. I think changing the section to a non slender one will be good.
