Hello fellow team,
I am experiencing some issue when running a model for analysis that contains sections created using Section Wizard. Before running I get these warning window/message:
The analysis is then cut short because Staad.Pro could not locate the relevant file. There exists no such file or folder specified below. Someone with a fix to this problem? I will really appreciate it.
Can you plaese check if temporary location is checked or not ? See below snap.
If this is checked, uncheck it and try.
Problem solved! Thank you a lot!
Cheers!!
