I am trying to analyse an aluminium frame but sections to be used are not in database so I tried USERTABLE and made 2 sections First is 30x20x1.4 mm channel section and second is SHS 40x40x1.4 . After runing analysis it throughout an error as in subject line...... I read other posts regarding this same issue but could not reach to solution how previously it was solved for others.
You should use the following commands-
MEMBER PROPERTY
20 22 24 25 27 31 32 35 UPTABLE 1 30X20X1.4
1 TO 18 36 TO 53 UPTABLE 2 UAE-40X40X1.4
Please refer to the attached mdel.
4478.CANOPY.std
I used your file and modified my file also both gives error like.
*warning* Member# 1 is not a valid Aluminium Section.
And so on for all members
0 errors , 90+ warnings of this type..... No Design result of Aluminium due to warnings of this type
Sir help here, what to do now after these warnings
At this point, STAAD.Pro can only design aluminum sections assigned from the Aluminum property tables supplied with STAAD. The warnings that you are getting is indicating this as user defined sections can't be designed.
