Assigning tapered section using OpenSTAAD
Dear Friends,
The script below is for a very simple model (single member). I'm trying to assign a steel tapered section (200 5 800 150 10 150 10), but I'm facing some troubles. Could you help me with the script?
Sub GenerateModel()
Dim cx(1) As Double
Dim cy(1) As Double
Dim cz(1) As Double
Dim Node(1) As Integer
Set suro = GetObject(, "StaadPro.OpenSTAAD")
Set OSGeometry = suro.geometry
Set OSProperty = suro.Property
For i = 0 To 1
cx(i) = i
cy(i) = i * 4
cz(i) = 0
Node(i) = suro.geometry.CreateNode((i + 1), cx(i), cy(i), cz(i))
Next
Beam = suro.geometry.CreateBeam(1, 1, 2)
End Sub
Parents Reply Children
