How to reduce shear force for shear wall sitting on semi rigid transfer slab ?
I analyze my model using ram structural system and design the shear wall using ram concrete but I found out that my shear wall located at transfer level have exceptionally high shear force.
Parents Reply
  • Hi Seth, anyway to reduce the shear force for the lateral walls? My transfer slab is modelled as a semi-rigid diaphragm and I've included out-of-plane stiffness for semi-rigid diaphragm with two way decks for lateral loads. In RAM Concrete analysis, I've also tried to ignore wall stiffness on above story. All of these options still does not help to reduce the shear force for walls.
    Or can we consider 'enhanced shear' for shear wall design in RAM Concrete, is there any option for it?
