Dear all,
I'm using STAAD.Pro CONNECT Edition V22 Update 11.
After the analysis, I would need to extract thru OPENSTAAD the info related to design of members with AISC/EC3 codes (I'm referring to member capacities, EC3 section class, etc.).
In a older Staad.Pro installation, with the function "GetSteelDesignResults" it was possible to get these data.
With the actual installation (reference library is now OPENSTAADUI), the similar function "GetMemberSteelDesignResults" does not give all the info.
Is there any other function to get these design results? Any suggestion?
Thank you!
Dear Shreyanka,
thank you very much for your prompt answer.
The values I'm looking for are the ones related to design strength (AISC) / design capacities (EC3) (please see attached screenshots).
Please correct me if I'm wrong, but the function "GetMemberSteelDesignResults" does not give these data.
In particular the one very helpful would be the Section Class as per EC3.
Thank you again
