I'm trying to optimise my steel sections for a linear static analysis but unfortunately after clicking the analysis to be done after the select command, the add button is greyed out. Then I get the message that select is not followed by a re-analysis. I have created my model to the physical modeler.
Could you please help?
CS5SP floor frame.STD
You may add the PERFORM ANALYSIS command after the SELECT command directly in the input file by using STAAD Editor.
I've tried to add it and I was kicked out of the program. I get an error indication now and I cannot enter the file. Any idea?
regards
What error do you get? Can you attach that file?
