RCDC - Column design output table
Dear,
In the column design as per EN 1992, in the output design table for the permissible slenderness limit, it seems that ''20'' is missing,
in the formula: 20*A*B*C/sqrt(n).
Parents Reply Children
  • 1) is it possible to edit the link arrangement only for a specific column? i took time and did the design of 60+ columns one by one and as the last column needed the shear link as close as 75mm c/c i tried to modify the link arrangement Sweat and to my horror all the column design changed with their links spaced at 125, 150, 175 c/c (which came safe earlier for 200 c/c)
    2) appreciate your support, if you could guide me in using the 'auto-group columns'.. because every time i change the reinforcement of columns and hoping the program to auto-group as per my manual design, the program insteSweat groups the columns and re-designs all - changing the reinforcements again Sweat
    (RCDC 2023 v 23.00.02.43)
