i did two models for steady state analysis, only the dynamic loads have been revised, but the results appear huge difference.
1. the first model with a bigger load, the result of velocity in x direction at node 712 is 1.8 mm/sec.
2. the second model with a small load, the result of velocity in x direaction atr node 712 is 125 mm/sec.
did anyone has this experience? or a bug in steady state analysis?
1. first model:
Loads:
***** screens***********254120-SEP-00005******1932 FY -97 1932 FZ -97 1932 FX -9.7 ****254120-SEP-00006******1941 FY -97 1941 FZ -97 1941 FX -9.7
2. second model:
loads:
***** screens***********254120-SEP-00005******1932 FY -70 1932 FZ -70 1932 FX -9.7 ****254120-SEP-00006******1941 FY -70 1941 FZ -701941 FX -9.7
Results:
On the first look, it does not appear to be logical. How about the deformation response? Do you get that as expected?
I have tested a couple of files at my end and the results are as expected.
Will it be possible for you to send us the file to have a look at?
Sudip Narayan Choudhury
thank you so much for the reply. this does not occur on other models. there is some confidential reason, i could not upload file.
iris
