I am trying modelling a simply supported plate model in staad with 10×10 mesh with density 25 Knm2 and E2510^6 and comparing it with results of other finite element applications and also with numerical matrix analysis by hand calculations. Both fem app and hand calculations results match but those of staad pro doesn't. Though I was sure of correct modelling and also checked for equilibrium each time, I tried models of other dimensions l b and h as well. Each time fem results and hand calculations matched perfectly.
For example I tried modeling 35×50 m plate with 2m depth. Hand and fem calculation results were 30 and 33 mm at centre resp. But staad gives 300mm. For other models also the result are far too variable like this case only. Please I need urgent support. Any reference would be appreciated.
Did you mesh your plate?what was the size of your mesh?
Attach your Staad model and your hand calculation so that you can get assistance from bentley technical team
For 5*5 m plate of 100mm thickness with SS corners and same mesh divisions and density and E also is giving this very variation. Staad gives 16.8mm approx at center due to self wt but other Fem applications ( ETABS ) and hand calcs gives 2.7mm approx.
I have many more models showing this high variation of results for various aspect ratios.
Explain? Are staad pro plate deflection calculations results expressed in different norms than conventional?
Answer Verified By: Atul Sharma
It is hard to comment without seeing that STAAD.Pro model. Please attach it and your hand calculations if possible.
staad model
I think the difference might be due to different support conditions. Make sure that STAAD.Pro model uses the same support conditions for the slab as considered in the manual calculation.
