RAM SS AISI 310-16 Diaphragm Stiffness
Hello
The Diaphragm shear stiffness formula has changed based on the AISI 310-16 and this results in a much higher shear stiffness. Following the procedure suggested by RAM Calculating Semirigid Diaphragm E'... this results in a E' value that is 3-4x higher than it was previously. Is there a new method to determine E' based on the new formula by AISI 310-16 instead if the SDI method?
Thanks!
