Anchor Shear - RAM SS - Ram Connection
The shear check for the anchor rods is showing a value of 5.5 kips for each anchor and since there are 4 anchors on the base plate this equates to 22 kips which is the greatest positive shear from the load combinations.  There is however a bigger shear in the anchor rods but is negative due to the load combinations at 43.8 kips which would equate to 10.95 kips per anchor.  Is this an oversight by RAM Connection to not also check the biggest negative shear?
