staad pro ce
HELLO EVERYONE,
MY QUESTION IS WHEN I COMPARE TWO MODELS ONE WITH OFFSET COMMAND AND THE OTHER WITHOUT OFFSET AND IN BOTH MODELS I M GETTING DIFFERENT RESULTS WHY???
1.0 Steel requirement in the top column is less in the offset model as compared to the without offset model.
2.0 Moment in the z-direction is less in the grid beam as compared to without offset model.
3.0 can we design the ring beam in staad if not then pls tell me for which moment we can go for a manual calculation.
Both the model attached belo0363.225 kl 10 m stg R1.STD0363.225 kl 10 m stg.STDw.
Parents Reply Children
