i only run the frequency up to 15 HZ, this appears weird result (chart) from staad, but the data file output from staad is ok.
can i set up the frequency (for example up to 15 HZ) for the graph directly from staad result?
Steady State Graph Data *************** Node No : 773 ************** Graph Type : Frequency - Velocity Direction - Y Frequency Velocity Hz mm/sec 0.303650 0.000000 0.562298 0.000000 0.598016 0.000000 0.607299 0.000000 0.616583 0.000000 0.652300 0.000000 0.688017 0.000000 0.697301 0.000000 0.716015 0.000000 0.788013 0.000000 0.860011 0.000000 0.878725 0.000000 0.879741 0.000000 0.883652 0.000000 0.887564 0.000000 0.888580 0.000000 0.897092 0.000000 0.929840 0.000000 0.962588 0.000000 0.971099 0.000000 0.977695 0.000000 1.003070 0.000000 1.028445 0.000000 1.035040 0.000000 1.037574 0.000000 1.047324 0.000000 1.057074 0.000000 1.059608 0.000000 1.061270 0.000000 1.067665 0.000000 1.074060 0.000000 1.075722 0.000000 1.075754 0.000000 1.075878 0.000000 1.076003 0.000000 1.076035 0.000000 1.100647 0.000000 1.195337 0.000000 1.290027 0.000000 1.314639 0.000000 1.317396 0.000000 1.328004 0.000000 1.338611 0.000000 1.341369 0.000000 1.347869 0.000000 1.372879 0.000000 1.397889 0.000000 1.404390 0.000000 1.413432 0.000000 1.448220 0.000000 1.483008 0.000000 1.492050 0.000000 1.498703 0.000000 1.500000 0.084986 1.524298 0.078862 1.549894 0.069707 1.556546 0.067656 1.556548 0.067656 1.556552 0.067655 1.556557 0.067653 1.556558 0.067653 1.564703 0.065326 1.596037 0.057846 1.627372 0.052312 1.635516 0.051461 1.636326 0.051404 1.639440 0.051246 1.642554 0.051200 1.643364 0.051210 1.646274 0.051327 1.657472 0.053209 1.668669 0.056977 1.671579 0.057958 1.674279 0.058751 1.684666 0.060041 1.695052 0.058309 1.697752 0.057533 1.699200 0.057092 1.704771 0.055352 1.710341 0.053742 1.711789 0.053364 1.728304 0.050225 1.791841 0.045124 1.855378 0.042368 1.871893 0.041282 1.874725 0.041080 1.885622 0.040379 1.896519 0.039843 1.899351 0.039722 1.910583 0.039267 1.953796 0.037898 1.997009 0.037158 2.008241 0.036989 2.008557 0.036984 2.009776 0.036964 2.010995 0.036944 2.011312 0.036939 2.028304 0.036651 2.093681 0.035976 2.159058 0.035096 2.176051 0.033996 2.176664 0.033948 2.179023 0.033760 2.181382 0.033570 2.181995 0.033521 2.195264 0.032586 2.246315 0.032056 2.297366 0.032426 2.310636 0.032437 2.318373 0.032425 2.348143 0.032359 2.377912 0.032298 2.385650 0.032271 2.385720 0.032271 2.385991 0.032269 2.386262 0.032268 2.386332 0.032268 2.391795 0.032243 2.412810 0.032080 2.420000 0.031996 2.433826 0.032160 2.439288 0.032227 2.449899 0.032383 2.490720 0.033198 2.531541 0.033627 2.542151 0.033669 2.542648 0.033673 2.544558 0.033687 2.546469 0.033705 2.546965 0.033710 2.547162 0.033713 2.547916 0.033722 2.548671 0.033732 2.548867 0.033734 2.549436 0.033743 2.551625 0.033779 2.553814 0.033823 2.554383 0.033836 2.556206 0.033882 2.563218 0.034115 2.570231 0.034416 2.572054 0.034498 2.573077 0.034543 2.577014 0.034706 2.580950 0.034838 2.581973 0.034865 2.586477 0.034938 2.603803 0.034242 2.621129 0.032025 2.625632 0.031324 2.628870 0.030819 2.641324 0.029006 2.653778 0.027558 2.657015 0.027250 2.657880 0.027173 2.661206 0.026896 2.664532 0.026650 2.665397 0.026591 2.675863 0.026031 2.716130 0.023644 2.756397 0.032069 2.766863 0.046454 2.769392 0.050787 2.779121 0.070030 2.788850 0.092450 2.791379 0.098641 2.793447 0.103782 2.801403 0.123996 2.809359 0.144477 2.811427 0.149798 2.816435 0.162655 2.835705 0.211906 2.854974 0.258510 2.859983 0.269129 2.865858 0.280485 2.888465 0.316327 2.911071 0.352638 2.916946 0.362267 2.920145 0.367302 2.932452 0.384366 2.944758 0.397273 2.947957 0.400071 2.948545 0.400567 2.950808 0.402431 2.953071 0.404233 2.953659 0.404694 2.966414 0.414392 3.015486 0.469942 3.064558 0.518973 3.077313 0.499891 3.083272 0.484124 3.106198 0.396085 3.129124 0.300695 3.135083 0.278700 3.135593 0.276889 3.137556 0.270032 3.139519 0.263353 3.140030 0.261646 3.140419 0.260353 3.141916 0.255443 3.143413 0.250639 3.143802 0.249408 3.146272 0.241757 3.155778 0.215028 3.165283 0.192589 3.167753 0.187456 3.179749 0.166667 3.225899 0.154002 3.272049 0.218124 3.284044 0.230454 3.291079 0.234380 3.318145 0.227556 3.345211 0.202738 3.352245 0.195706 3.358987 0.189029 3.384925 0.164920 3.410862 0.144504 3.417604 0.139862 3.426191 0.134326 3.459232 0.116556 3.492272 0.103737 3.500860 0.101220 3.503400 0.100540 3.513172 0.098191 3.522945 0.096213 3.525485 0.095749 3.528216 0.095269 3.538721 0.093558 3.549226 0.091977 3.551956 0.091576 3.560498 0.090333 3.593362 0.085727 3.626226 0.081806 3.634768 0.080933 3.639666 0.080457 3.658513 0.078757 3.677360 0.077161 3.682259 0.076745 3.683815 0.076612 3.689799 0.076098 3.695784 0.075578 3.697339 0.075442 3.706479 0.074642 3.741641 0.071887 3.776804 0.070281 3.785943 0.070080 3.786362 0.070073 3.787974 0.070048 3.789586 0.070025 3.790005 0.070020 3.790877 0.070009 3.794234 0.069975 3.797591 0.069954 3.798464 0.069951 3.814455 0.070038 3.875975 0.073590 3.937495 0.087898 3.953486 0.096150 3.953832 0.096361 3.955165 0.097188 3.956498 0.098036 3.956844 0.098260 3.967518 0.105925 4.008583 0.151028 4.049649 0.225528 4.060322 0.248408 4.064489 0.257332 4.080518 0.289712 4.096548 0.315217 4.100714 0.320178 4.102483 0.322047 4.109287 0.327863 4.116091 0.331460 4.117859 0.332034 4.121651 0.332776 4.136239 0.329954 4.150827 0.320132 4.154618 0.316819 4.155262 0.316235 4.157738 0.313936 4.160214 0.311569 4.160858 0.310944 4.163451 0.308393 4.173429 0.298312 4.183408 0.288325 4.186001 0.285812 4.189221 0.282762 4.201610 0.271915 4.213998 0.262731 4.217218 0.260630 4.219426 0.259256 4.227919 0.254452 4.236412 0.250332 4.238619 0.249357 4.241815 0.248008 4.254111 0.243378 4.266406 0.239385 4.269602 0.238422 4.286578 0.233703 4.351888 0.221989 4.417198 0.221967 4.434173 0.223784 4.449026 0.225965 4.506168 0.239607 4.563310 0.262041 4.578162 0.269369 4.581332 0.271020 4.593526 0.277687 4.605720 0.284900 4.608889 0.286872 4.624549 0.297254 4.684799 0.347621 4.745048 0.399780 4.760708 0.405527 4.765135 0.405911 4.782167 0.400953 4.799199 0.384379 4.803626 0.378127 4.812098 0.364123 4.844696 0.293779 4.877293 0.222378 4.885765 0.206818 4.896451 0.189669 4.937563 0.150990 4.978675 0.141178 4.989361 0.139621 4.993178 0.139064 5.007862 0.137212 5.022546 0.136846 5.026363 0.137189 5.036663 0.139329 5.076291 0.166557 5.115919 0.215064 5.126219 0.228223 5.129950 0.232796 5.144307 0.248599 5.158663 0.259898 5.162394 0.261817 5.163636 0.262348 5.168412 0.263857 5.173188 0.264466 5.174430 0.264469 5.175856 0.264391 5.181343 0.263254 5.186829 0.260743 5.188255 0.259859 5.195942 0.253433 5.225516 0.203688 5.255089 0.125399 5.262776 0.103486 5.265880 0.094798 5.277821 0.064186 5.289762 0.045739 5.292866 0.044840 5.294134 0.045027 5.299012 0.048503 5.303891 0.055396 5.305159 0.057577 5.309598 0.066044 5.326679 0.103399 5.343760 0.140880 5.348199 0.150300 5.354664 0.163766 5.379537 0.213242 5.404410 0.259886 5.410875 0.271549 5.413658 0.276500 5.424365 0.295088 5.435073 0.312800 5.437856 0.317233 5.443262 0.325616 5.464064 0.354456 5.484865 0.376198 5.490271 0.380420 5.501148 0.386942 5.542992 0.388135 5.584836 0.362180 5.595712 0.353169 5.597157 0.351941 5.602718 0.347185 5.608278 0.342412 5.609724 0.341174 5.611518 0.339643 5.618421 0.333825 5.625324 0.328197 5.627118 0.326777 5.628254 0.325888 5.632621 0.322553 5.636989 0.319364 5.638125 0.318561 5.641919 0.315963 5.656515 0.307329 5.671112 0.301141 5.674906 0.299959 5.688461 0.297181 5.740614 0.304126 5.792767 0.319233 5.806323 0.320687 5.812298 0.320864 5.835290 0.319431 5.858281 0.316729 5.864257 0.316213 5.864695 0.316181 5.866380 0.316069 5.868066 0.315973 5.868504 0.315950 5.871738 0.315819 5.884181 0.315967 5.896624 0.317287 5.899858 0.317832 5.900198 0.317894 5.901506 0.318142 5.902814 0.318403 5.903154 0.318473 5.908812 0.319768 5.930581 0.326839 5.952349 0.336437 5.958007 0.339204 5.958992 0.339693 5.962780 0.341595 5.966569 0.343521 5.967554 0.344025 5.973415 0.347044 5.995967 0.358576 6.018519 0.369722 6.024381 0.372223 6.030875 0.374686 6.055857 0.380126 6.080840 0.376894 6.087334 0.374427 6.088220 0.374039 6.091630 0.372439 6.095040 0.370672 6.095927 0.370186 6.098724 0.368587 6.109487 0.361602 6.120249 0.353693 6.123047 0.351560 6.127211 0.348370 6.143231 0.336544 6.159250 0.326737 6.163414 0.324665 6.165951 0.323506 6.175710 0.319780 6.185470 0.317111 6.188006 0.316563 6.189893 0.316188 6.197151 0.314960 6.204409 0.313958 6.206296 0.313715 6.207944 0.313506 6.214284 0.312684 6.220624 0.311772 6.222272 0.311511 6.236087 0.308742 6.289238 0.288478 6.342389 0.272321 6.356204 0.271231 6.359327 0.271179 6.371340 0.271650 6.383353 0.273208 6.386475 0.273795 6.396030 0.276058 6.432791 0.290631 6.469553 0.307601 6.479108 0.310623 6.485473 0.312072 6.509961 0.312763 6.534450 0.305922 6.540815 0.303152 6.545365 0.300979 6.562872 0.291509 6.580379 0.281071 6.584929 0.278313 6.591128 0.274572 6.614975 0.260800 6.638822 0.248823 6.645021 0.246096 6.652180 0.243169 6.679725 0.234295 6.707270 0.229214 6.714430 0.228394 6.716300 0.228203 6.723495 0.227531 6.730690 0.226917 6.732560 0.226760 6.736159 0.226451 6.750003 0.225085 6.763848 0.223165 6.767446 0.222544 6.768670 0.222321 6.773380 0.221403 6.778090 0.220393 6.779314 0.220116 6.785909 0.218524 6.811279 0.211315 6.836649 0.204068 6.843244 0.202446 6.850400 0.200863 6.877930 0.196510 6.905461 0.193563 6.912617 0.192641 6.920101 0.191472 6.948896 0.183912 6.977690 0.169870 6.985175 0.165127 6.991257 0.160999 7.014658 0.143907 7.038059 0.129368 7.044142 0.127058 7.044274 0.127018 7.044785 0.126866 7.045296 0.126721 7.045429 0.126685 7.054264 0.125385 7.088253 0.144528 7.122243 0.195065 7.131078 0.210958 7.139299 0.226240 7.170930 0.285752 7.202561 0.338707 7.210782 0.350316 7.216452 0.357684 7.238267 0.380793 7.260082 0.395400 7.265752 0.397859 7.273409 0.400359 7.302870 0.402174 7.332331 0.394301 7.339989 0.391097 7.360425 0.380819 7.439049 0.323829 7.517673 0.235238 7.538109 0.214494 7.542119 0.211460 7.557546 0.204490 7.572973 0.206244 7.576983 0.208158 7.579388 0.209575 7.588640 0.216726 7.597892 0.226102 7.600297 0.228817 7.602336 0.231191 7.610182 0.240788 7.618027 0.250813 7.620067 0.253442 7.623261 0.257551 7.635550 0.272928 7.647839 0.286895 7.651034 0.290201 7.654065 0.293197 7.665727 0.303334 7.677389 0.311092 7.680420 0.312704 7.680442 0.312715 7.680526 0.312758 7.680610 0.312800 7.680632 0.312811 7.684830 0.314750 7.700983 0.319266 7.717136 0.319395 7.721334 0.318780 7.722155 0.318630 7.725314 0.317970 7.728473 0.317179 7.729294 0.316952 7.738263 0.313948 7.772770 0.295256 7.807278 0.269543 7.816247 0.262243 7.816859 0.261739 7.819213 0.259797 7.821566 0.257846 7.822178 0.257338 7.825078 0.254924 7.836235 0.245581 7.847392 0.236244 7.850292 0.233833 7.852680 0.231855 7.861868 0.224334 7.871056 0.217002 7.873444 0.215134 7.879168 0.210732 7.901189 0.194956 7.923211 0.181356 7.928934 0.178200 7.931766 0.176696 7.942658 0.171244 7.953551 0.166281 7.956382 0.165062 7.964182 0.161837 7.994189 0.150707 8.024196 0.140819 8.031995 0.138372 8.038041 0.136524 8.061300 0.130094 8.084559 0.125527 8.090605 0.124771 8.093094 0.124520 8.102672 0.123889 8.112250 0.123807 8.114740 0.123875 8.135152 0.125749 8.213688 0.142023 8.292223 0.133994 8.312636 0.124269 8.318211 0.121098 8.339661 0.107167 8.361110 0.091199 8.366686 0.086841 8.377423 0.078331 8.418731 0.046512 8.460039 0.025385 8.470776 0.024413 8.487551 0.027388 8.552090 0.056516 8.616629 0.085956 8.633404 0.093193 8.648590 0.099655 8.707019 0.123993 8.765447 0.147143 8.780634 0.152841 8.784067 0.154109 8.797275 0.158929 8.810483 0.163670 8.813916 0.164893 8.820288 0.167156 8.844805 0.175850 8.869321 0.184707 8.875693 0.187063 8.879995 0.188670 8.896545 0.194987 8.913094 0.201541 8.917396 0.203285 8.921977 0.205162 8.939602 0.212559 8.957228 0.220225 8.961809 0.222257 8.962146 0.222407 8.963441 0.222985 8.964736 0.223564 8.965073 0.223715 8.973568 0.227544 9.006251 0.242687 9.038935 0.258325 9.047430 0.262448 9.052724 0.265027 9.073090 0.275006 9.093457 0.285040 9.098751 0.287650 9.110182 0.293278 9.154164 0.314439 9.198145 0.333604 9.209577 0.338112 9.214735 0.340085 9.234583 0.347391 9.254430 0.354472 9.259589 0.356324 9.263596 0.357774 9.279011 0.363531 9.294426 0.369701 9.298433 0.371391 9.307843 0.375516 9.344046 0.393363 9.380250 0.412573 9.389660 0.417215 9.390778 0.417744 9.395081 0.419727 9.399384 0.421616 9.400503 0.422090 9.402162 0.422779 9.408547 0.425259 9.414932 0.427435 9.416592 0.427944 9.421177 0.429221 9.438816 0.432045 9.456454 0.430789 9.461039 0.429677 9.461356 0.429588 9.462575 0.429227 9.463794 0.428841 9.464111 0.428736 9.469141 0.426841 9.488493 0.415235 9.507845 0.396442 9.512875 0.390378 9.521510 0.378875 9.554731 0.323402 9.587952 0.256657 9.596587 0.238790 9.597516 0.236875 9.601090 0.229532 9.604664 0.222237 9.605593 0.220351 9.615163 0.201222 9.651983 0.136762 9.688804 0.097928 9.698374 0.093708 9.703328 0.092542 9.722385 0.093970 9.741442 0.102715 9.746395 0.105812 9.747385 0.106463 9.751194 0.109052 9.755003 0.111766 9.755992 0.112490 9.762590 0.117487 9.787973 0.138605 9.813356 0.161105 9.819954 0.167003 9.830543 0.176435 9.871284 0.211290 9.912025 0.241851 9.922614 0.248905 9.938512 0.258829 9.999678 0.292301 10.060844 0.328144 10.076742 0.338612 10.077519 0.339133 10.080507 0.341145 10.083496 0.343167 10.084273 0.343694 10.088868 0.346820 10.106548 0.358901 10.124228 0.370771 10.128823 0.373772 10.131885 0.375744 10.143666 0.383100 10.155447 0.390015 10.158509 0.391730 10.163908 0.394667 10.184677 0.404869 10.205447 0.413329 10.210846 0.415263 10.214371 0.416472 10.227931 0.420761 10.241492 0.424566 10.245017 0.425490 10.245824 0.425699 10.248928 0.426490 10.252033 0.427265 10.252840 0.427464 10.262556 0.429795 10.299940 0.438072 10.337323 0.445765 10.347040 0.447591 10.352531 0.448566 10.373660 0.451789 10.394789 0.453857 10.400280 0.454160 10.406362 0.454372 10.429758 0.453931 10.453155 0.451584 10.459237 0.450707 10.467478 0.449378 10.499186 0.443266 10.530893 0.436708 10.539135 0.435049 10.548172 0.433262 10.582942 0.426509 10.617712 0.419074 10.626749 0.416864 10.628140 0.416510 10.633492 0.415115 10.638844 0.413662 10.640235 0.413275 10.651703 0.409921 10.695825 0.394366 10.739947 0.375508 10.751416 0.370293 10.759150 0.366732 10.788908 0.352806 10.818666 0.338580 10.826401 0.334825 10.832783 0.331705 10.857339 0.319482 10.881895 0.306857 10.888278 0.303505 10.888706 0.303280 10.890352 0.302410 10.891997 0.301539 10.892425 0.301312 10.900866 0.296811 10.933341 0.279107 10.965816 0.261063 10.974257 0.256377 10.985988 0.249899 11.031119 0.225754 11.076250 0.203635 11.087981 0.198309 11.098114 0.193861 11.137099 0.178115 11.176083 0.164548 11.186216 0.161377 11.197708 0.157960 11.241920 0.146693 11.286132 0.138859 11.297623 0.137464 11.301535 0.137052 11.316583 0.135764 11.331632 0.134936 11.335543 0.134792 11.346594 0.134536 11.389111 0.135216 11.431627 0.137257 11.442678 0.137799 11.456580 0.138414 11.510066 0.139573 11.563551 0.138395 11.577453 0.137737 11.584166 0.137376 11.609991 0.135762 11.635816 0.133886 11.642528 0.133374 11.645359 0.133156 11.656251 0.132313 11.667142 0.131473 11.669973 0.131257 11.676655 0.130752 11.702363 0.128927 11.728070 0.127398 11.734752 0.127063 11.741582 0.126749 11.767857 0.125820 11.794133 0.125289 11.800962 0.125200 11.803547 0.125170 11.813490 0.125068 11.823434 0.124977 11.826019 0.124953 11.827776 0.124936 11.834536 0.124868 11.841296 0.124788 11.843053 0.124765 11.853691 0.124595 11.894619 0.123131 11.935546 0.119602 11.946184 0.118258 11.950875 0.117606 11.968919 0.114760 11.986964 0.111391 11.991654 0.110434 11.995863 0.109547 12.012058 0.105912 12.028253 0.101959 12.032462 0.100887 12.037813 0.099502 12.058396 0.093977 12.078980 0.088258 12.084331 0.086759 12.097629 0.083036 12.148790 0.069278 12.199952 0.057033 12.213250 0.054049 12.216063 0.053423 12.226885 0.051022 12.237708 0.048619 12.240521 0.047992 12.246786 0.046589 12.270889 0.041066 12.294993 0.035278 12.301258 0.033737 12.307547 0.032184 12.331743 0.026380 12.355939 0.022002 12.362228 0.021424 12.377629 0.021596 12.436883 0.043914 12.496136 0.086051 12.511537 0.099002 12.515194 0.102176 12.529264 0.114718 12.543333 0.127731 12.546990 0.131183 12.550662 0.134675 12.564790 0.148333 12.578918 0.162288 12.582590 0.165954 12.590851 0.174246 12.622632 0.206442 12.654414 0.238286 12.660000 0.243762 12.662674 0.246380 12.664548 0.248207 12.671755 0.255173 12.678962 0.262033 12.680836 0.263796 12.692028 0.274153 12.735088 0.310399 12.778148 0.339358 12.789340 0.345519 12.793925 0.347875 12.811562 0.356023 12.829200 0.362738 12.833785 0.364254 12.844046 0.367314 12.883526 0.375063 12.923005 0.377243 12.933266 0.377039 12.940335 0.376735 12.967532 0.374458 12.994729 0.370759 13.001798 0.369627 13.009281 0.368373 13.038073 0.363261 13.066864 0.358297 13.074347 0.357132 13.094343 0.354440 13.171272 0.352695 13.248201 0.365688 13.268196 0.370538 13.275248 0.372296 13.302380 0.379023 13.329512 0.385254 13.336564 0.386729 13.339723 0.387367 13.351879 0.389673 13.364034 0.391727 13.367194 0.392217 13.372966 0.393063 13.395173 0.395711 13.417379 0.397365 13.423151 0.397629 13.432902 0.397920 13.470416 0.397196 13.507929 0.393460 13.517680 0.391980 13.519390 0.391699 13.525971 0.390556 13.532551 0.389318 13.534261 0.388980 13.536792 0.388469 13.546527 0.386376 13.556263 0.384085 13.558793 0.383458 13.564574 0.381979 13.586815 0.375721 13.609055 0.368702 13.614836 0.366779 13.625337 0.363205 13.665738 0.348889 13.666000 0.348795 13.706140 0.334759 13.716641 0.331208 13.720068 0.330063 13.733255 0.325735 13.746441 0.321530 13.749869 0.320458 13.758497 0.317796 13.791695 0.308036 13.824892 0.298892 13.833521 0.296583 13.842816 0.294115 13.878576 0.284690 13.914337 0.275141 13.923632 0.272614 13.930749 0.270665 13.958132 0.263074 13.985515 0.255409 13.992633 0.253424 13.996501 0.252348 14.011382 0.248248 14.026263 0.244231 14.030131 0.243205 14.032471 0.242588 14.041475 0.240248 14.050478 0.237965 14.052819 0.237381 14.055461 0.236728 14.065627 0.234270 14.075792 0.231908 14.078434 0.231311 14.084106 0.230055 14.105924 0.225558 14.127742 0.221654 14.133413 0.220745 14.136243 0.220308 14.147128 0.218736 14.158014 0.217339 14.160843 0.217006 14.162026 0.216870 14.166576 0.216369 14.171126 0.215899 14.172308 0.215783 14.184502 0.214711 14.231414 0.212851 14.278326 0.214528 14.290519 0.215501 14.293806 0.215798 14.306453 0.217075 14.319099 0.218553 14.322386 0.218968 14.326662 0.219527 14.330000 0.219977 14.340000 0.221426
I have informed our development team about this issue through a Help Ticket. For the time being you can try manually plotting the graph using frequency-velocity data in an excel to get around this issue.
Hello Iris,Can you please share the .STD file with us? We need it to investigate this issue
