369. TYPE 1 WIND 370. <! STAAD PRO GENERATED DATA DO NOT MODIFY !!! 371. IS875-2015:PARAMS 0 0 0 9.600 0.000 3.000 0 JAMSHEDPUR 47.000 0 1.000 1 5 - 372. 1.000 1.000 1.000 1.000 1.000 1.000 2 1.000 0.020 0 49.760 24.350 12.600 0 0 - 373. 0 1.000 0 0 0.200 1.000 0 1.000 1.000 1.000 374. !> END GENERATED DATA BLOCK 375. INT 1.325 1.325 1.325 1.325 1.325 HEIG 0 3 6 9 9.6 376. EXP 1 JOINT 240 TO 256 258 TO 296 298 TO 336 338 TO 376 378 TO 380 - 377. 386 TO 388 390 TO 392 394 TO 396 398 430 TO 541 554 TO 573 583 TO 630 378. ONEWAY LOAD
*** ERROR *** ABOVE COMMAND IS NOT RECOGNIZED. LINE IGNORED.
R1A_INSDAG_RHO_0911022.STD
The below highlighted lines are misplaced. They should be under some primary load case. Please review and change.
Also the Y range used for wind load cases are not a valid one. You have used a range of 0 to 9.6m where the structure starts from 12.6m.
Correct these ranges and try again.
Answer Verified By: Raju Odedara
Thank You For Answering.
