Anybody Knows about SCON command, how it works? there is no info about it
Can you please mention which software you are talking about?Is there any snap available for the same?
Hi Abhisek, thank you, that command is from Staad Pro, Slab design BS code
Parameter SCON indicates the type of slab i.e. ground or suspended as defined in BS8007
