WT sections in STAADpro
1) Why is STAAD not using the property I specified in the design, I noticed this is specific to WT section or sections cut from wide flange. Is there a way to force STAAD to use the sections I specified in the design? I have looked through the manual but couldn’t find an answer.
2) Also, if I select W8x16 and T section, STAAD assigns WT4X8. Why is this?
