TRUE SOUTH AESTHETIC SINGLE.STD
Copy the STAAD file to a new folder and rerun and try to import. If the issue persists, create a service request. In the service request, please mention the version of RCDC and STAAD.Pro you are currently using.
not resolved after copy option..
Anybody can give me solution??
I need to resolve this on urgent basis..
Dear Sir,
Can you please raise a service request from the below link and also attach a staad file along in the SR for us to investigate further .
https://apps.bentley.com/srmanager/?_ga=2.165086463.1144693128.1669002300-1173522962.1655807202
I investigated your model and found that the file has been created from some dxf import and due to that (may be) there are some issues in detection of level data. I am not sure what the exact problem is and will investigate further. But as of now I have found one workaround for the same.
1. Open the STAAD model in a notepad. Righ click on .std file and open with notepad)
2. Copy the whole content from notepad.
3. Open a new STAAD model.
4. Open input editor
5. Now delete the existing data in new editor and paste the data you have already copied.
6. Save & Close the editor file.
7. Now run the file and try.
I was able to import the file in this way. I am attaching the file I made following the above procedure.
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5932/Structure2_2D00_Column_2D00_1.rcdx7418.Structure2.STD
