Hello all,
I have been trying to model a truss. I have two bottom support, it can be fully fixed or partially fixed and I have two cable connection at the top. But this cable member should not take any compression, since I have Wind suction in that direction(I have considered that direction, let it be any possible load in that direction), it is taking compression which I understood from the direction of reaction loads. How can I turn this member as like a cable without warnings or errors.
At first, I had many errors when I was giving TRUSS specification to the members and later I have changed it into Partial Release of Moments Mx, My & Mz with 0.99 release. Now how can I solve this cable issue.
(What I would like to have is, if that two members are cable, then there should be only tension in the supports and members. How can I make that?)I am attaching the file here.
Thanks.
Truss study.std
Change the Pinned supports to Fixed and this will eliminate the warnings.
Answer Verified By: Mohamed P
Solved.
Thank you.
