Is there a way to name connection assignments in RAM Connection CE (not standalone)? I understand that the connection itself has a name, but I would like to name a group after its associative moment frame # that way I can utilize a single baseplate design for all the columns in that frame. If this is not currently a feature, it would be nice to have in the future. Thanks.
In Ram Connection for RAM Structural System? If so, after you select the group of columns and assign the base plate, then you can edit the Connection Description and "fill-down" in the spreadsheet like so:
Yes, RAM Connection for RAM SS. This helps. Thanks Seth!
