getpropertyname
Dim lMemberNo As Long
Dim lNodeA As Long
Dim lNodeB As Long
Dim icount As Integer
Dim dCoordX As Double
Dim dCoordY As Double
Dim dCoordZ As Double
Dim SelBeams() As Long
Dim strpropertyname As Variant
Dim isecrefno As String
Dim dWidth As Double
Dim dDepth As Double
Dim dax As Double
Dim Day As Double
Dim daz As Double
Dim dix As Double
Dim diy As Double
Dim diz As Double
Dim dtf As Double
Dim dtw As Double
Set objopenstaad = GetObject(, "StaadPro.OpenSTAAD")
Dim NoOfSelectedBeams As Long
NoOfSelectedBeams = objopenstaad.Geometry.GetNoOfSelectedBeams
If NoOfSelectedBeams = 0 Then
MsgBox "No Columns Selected ! Aborting...."
Exit Sub
End If
ReDim SelBeams(NoOfSelectedBeams - 1) As Long
objopenstaad.Geometry.GetSelectedBeams SelBeams, 1
For icount = 0 To (NoOfSelectedBeams - 1)
lMemberNo = SelBeams(icount)
objopenstaad.Geometry.GetMemberIncidence lMemberNo, lNodeA, lNodeB
Cells(2 + icount, 1).Value = lMemberNo
objopenstaad.Geometry.GetNodeCoordinates lNodeA, dCoordX, dCoordY, dCoordZ
Cells(2 + icount, 2).Value = lNodeA
Cells(2 + icount, 3).Value = dCoordX
Cells(2 + icount, 4).Value = dCoordY
Cells(2 + icount, 5).Value = dCoordZ
objopenstaad.Geometry.GetNodeCoordinates lNodeB, dCoordX, dCoordY, dCoordZ
Cells(2 + icount, 6).Value = lNodeB
Cells(2 + icount, 7).Value = dCoordX
Cells(2 + icount, 8).Value = dCoordY
Cells(2 + icount, 9).Value = dCoordZ
objopenstaad.Property.GetSectionPropertyName strpropertyname, isecrefno
Cells(2 + icount, 10).Value = strpropertyname
Cells(2 + icount, 11).Value = isecrefno
objopenstaad.Property.GetBeamPropertyAll dWidth, dDepth, dax, Day, daz, dix, diy, diz, dtf, dtw
Cells(2 + icount, 12).Value = dWidth
Cells(2 + icount, 13).Value = dDepth
Cells(2 + icount, 14).Value = dax
Cells(2 + icount, 15).Value = Day
Cells(2 + icount, 16).Value = daz
Cells(2 + icount, 17).Value = dix
Cells(2 + icount, 18).Value = diy
Cells(2 + icount, 19).Value = diz
Cells(2 + icount, 20).Value = dtf
Cells(2 + icount, 21).Value = dtw
Next
Set staad = Nothing
End Sub
i wrote this code to get necessary values but the property name and beam property are coming as null value .. please help
  • Some modification is required in this code
    • For GetSectionPropertyName function isecrefno is the input. You need to specify the value of variable isecrefno. You can also pass array index for function GetSectionPropertyName
    • The order of the arguments are correct for function GetSectionPropertyName
    • Input variable (beam number) is missing for function GetBeamPropertyAll
    • Variable type will be String for variable strpropertyname
    • Variable type will be Long for variable isecrefno
    After modification sample code:
    Dim lNodeA As Long
    Dim lNodeB As Long
    'Dim strpropertyname As Variant
    Dim strpropertyname As String
    'Dim isecrefno As String
    Dim isecrefno As Long
    Dim dax As Double
    Dim Day As Double
    Dim daz As Double
    Dim dix As Double
    Dim diy As Double
    Dim diz As Double
    Dim dtf As Double
    Dim dtw As Double
    Set objOpenStaad = GetObject(, "StaadPro.OpenSTAAD")
    NoOfSelectedBeams = objOpenStaad.Geometry.GetNoOfSelectedBeams
    Exit Sub
    End If
    objOpenStaad.Geometry.GetSelectedBeams SelBeams, 1
    objOpenStaad.Geometry.GetMemberIncidence lMemberNo, lNodeA, lNodeB
    objOpenStaad.Geometry.GetNodeCoordinates lNodeA, dCoordX, dCoordY, dCoordZ
    objOpenStaad.Geometry.GetNodeCoordinates lNodeB, dCoordX, dCoordY, dCoordZ
    isecrefno = 1
    'objOpenStaad.Property.GetSectionPropertyName strpropertyname, isecrefno
    objOpenStaad.Property.GetSectionPropertyName isecrefno, strpropertyname
    objOpenStaad.Property.GetBeamPropertyAll lMemberNo, dWidth, dDepth, dax, Day, daz, dix, diy, diz, dtf, dtw
    Next
    Set staad = Nothing
  • i want to get the property name for selected beam
  • You can use these two functions as per your requirement. Either GetBeamSectionDisplayName or GetBeamSectionName
