I was testing different heavy loads because I'm currently trying to practice STAAD as a college student. I tried to test a 50-ton load on a large beam. My mentor said it should be able to support that load but it keeps on failing when I design it on RCDC. Does anyone know how to fix this problem?
Can you please upload the RCDC file here?
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
Answer Verified By: jim perkins
thank youu for replying, my rcdc file wouldn't upload due to some error. so I uploaded the staad file instead.
50 ton load test.std
hello, can you help me with the problem please
Can you please let me know the design code you are using?
ACI 318M-2014 is the design code I used
