STAAD SPACESTART JOB INFORMATIONENGINEER DATE 05-Dec-22END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 10 0 0; 3 0 5 0; 4 10 5 0; 5 0 0 10; 6 10 0 10; 7 0 5 10; 8 10 5 10;9 1.66667 5 0; 10 3.33333 5 0; 11 5 5 0; 12 6.66667 5 0; 13 8.33333 5 0;14 1.66667 6 0; 15 3.33333 7 0; 16 5 8 0; 17 6.66667 7 0; 18 8.33333 6 0;19 1.66667 5 10; 20 3.33333 5 10; 21 5 5 10; 22 6.66667 5 10; 23 8.33333 5 10;24 1.66667 6 10; 25 3.33333 7 10; 26 5 8 10; 27 6.66667 7 10; 28 8.33333 6 10;MEMBER INCIDENCES1 3 9; 2 1 3; 3 2 4; 4 7 19; 5 5 7; 6 6 8; 7 3 7; 8 4 8; 9 9 10; 10 10 11;11 11 12; 12 12 13; 13 13 4; 14 19 20; 15 20 21; 16 21 22; 17 22 23; 18 23 8;19 3 14; 20 14 15; 21 15 16; 22 16 17; 23 17 18; 24 18 4; 25 9 14; 26 10 15;27 11 16; 28 12 17; 29 13 18; 30 10 14; 31 11 15; 32 11 17; 33 12 18; 34 7 24;35 24 25; 36 25 26; 37 26 27; 38 27 28; 39 28 8; 40 19 24; 41 20 25; 42 21 26;43 22 27; 44 23 28; 45 20 24; 46 21 25; 47 21 27; 48 22 28; 49 9 19; 50 10 20;51 11 21; 52 12 22; 53 13 23; 54 14 24; 55 15 25; 56 16 26; 57 17 27; 58 18 28;DEFINE MATERIAL STARTISOTROPIC STEELE 210POISSON 0.3DENSITY 76.8195ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2ISOTROPIC STAINLESSSTEELE 1.9793e+008POISSON 0.3DENSITY 76.8195ALPHA 1.8e-005DAMP 0.03END DEFINE MATERIALMEMBER PROPERTY AMERICAN19 TO 58 TABLE ST W6X91 TO 18 TABLE ST W8X48CONSTANTSMATERIAL STEEL ALLSUPPORTS1 2 5 6 FIXEDMEMBER RELEASE19 TO 48 54 TO 58 START MX MY MZDEFINE REFERENCE LOADSLOAD R1 LOADTYPE None TITLE REF LOAD CASE 1END DEFINE REFERENCE LOADSLOAD 1 LOADTYPE Dead TITLE LKJOINT LOAD3 4 7 8 14 TO 18 24 TO 28 FY -144PERFORM ANALYSISFINISH
When you assign the member release specification to the member, the moments on the specific degrees of freedom are released and no moments are transferred. I.e. if you assign MZ member release, it means that moment about the local Z axis is not transferred to another member, so the member is pinned in that direction. By default, all degrees of freedom are fixed in STAAD.Pro for each member, so if you want to model pinned connections, you need to assign member releases.
thx bro
Mechanical Engineer work at
