When SCBF selected in RAM Connection. Which option does RAM use? Does designer need to input Required Yield strength of braces manually? Or RAM can decide on member sizes? Or AISC341 _ 6.c_1_b) is considered? Thanks!
Please Help! Thanks!
6c.1(a), we don't have enough information to perform (b). In one of the older versions we were using the amplified seismic combos as a stand-in for (b), but that wasn't really accurate, so it was taken out.
