I am trying to import from Revit 2023 into RAM Elements, always get the same error. I made a Bentley and Autodesk complete clean install with the same result.
The same issue in most recent version 16.08.00.170
The members are being detected as "Non-structural"
Make sure that they are being created under the Structure ribbon in Revit instead of the Architectural one.
Thank you for your response. Sure, all the members were created under Structure ribbon. Only walls and slabs are caught by RAM Elements 16.08.00.170.
Could you please send us your ism file and your Revit file. You can attach it to this post or you can upload it through secure file upload
The file was too big to upload from this forum, I did so through "secure file upload" the file is "Model.7z"
