Staad V22 update10 version. Utilisation ratio is not coming in display for many members.
Only after keeping the cursor on the member it is seen in popup.
Help me on this problem.
Could be an issue of that version. Try to upgrade to the most recent STAAD.Pro CE version 22.12.00.142. If that does not solve the issue, please attach the model.
Problem actually solved. Since the model is quite big one, Check code command got split into many check codes. Only the first check code shows the utilisation ratio display. I grouped all members together and gave check code member _grp1. Now all members display ratio. Thanks for your effort.
Modestas then there is a bug in RCC design in update 11 and 12
Can you please let us know which issue you are facing for concrete design ? The above discussion is related to steel design and hence we are unable to understand your issue.
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
