Want to import the load combination reaction from ETABS to RAM concept, but the SAFE utility only allows to import the reactions corresponding to loads in ETABS.
Please let me know if there is a way to import the reactions from Load combinations also.
Thanks in advance!
Unfortunately, there is not a way to accomplish that through the utility.
Perhaps you could extract the reactions through the ETABS API and then import them into RAM Concept using its scripting API. Click on Help - API Documentation while working in RAM Concept to learn more about the scripting API.
