Does RC column design in RCDC "RCDC CONNECT Edition V11 Update 5", take care of requirements given in ACI-318, Cl 18.7.3 for Minimum Flexural strength of columns?
HI Vikas ,
The minimum strength of the column is checked in RCDC as per 18.7.3. (Flexural joint check of the column).a separate report is available for the joint check. A sample report is attached for reference.
Please refer joint check report to get this check
Joint check report.html
