I cannot change or customize the values in "Actual Ratio" within Design Results tab in Staad.Pro 22.12.00.142
I can select Detailed Diagram in Color section, reduce the No. of Bands, select colors every time, but in previous releases, this easy customization was directly done in Actual Ration and Basic Diagram. Now its locked.
Yes, some modifications were made in this area and now the customization can be made in the Detailed Diagram option only.
