Does STAAD Pro Connection edition support AS 1170.4 either as in-built or stand alone add-on?
If not, why not?
Mohamed
No, Australian Seismic Code is not implemented in STAAD.Pro. You can propose implementing this code here: STAAD.Pro Ideas Portal (aha.io) Other Community users could vote for it and the more votes it receives, the higher chances are that this will be implemented in STAAD.Pro in the future.
