Bolted Beam Splice Connection
Below is an image of a bolted beam splice connection that I'm working on.
RAM Connection considers the eccentricity of the bolt group to be 3.125in and the coefficient for eccentrically loaded bolt groups to be 8.
I believe that the eccentricity should be 6.25in and the coefficient should be approximately 3.5 (Table 7-7 from AISC360 15th edition; there isn't even an 8 option on this table given the parameters). Why does RAM connection select such a high coefficient for eccentrically loaded bolt groups? Why doesn't RAM consider eccentricity of the bolt group to be related to the adjacent bolt group?
