When the temperature load apply model seems abnormal. What is the reason
2703.std
To attached the summary table with temperature load (Image1),without temperature load (Image2).
Image 1
Image 2
ok thanks, i have used above links to calculated temperature load.
temperature at the stress-free condition for me is 28.15 degree C.../
00.std
When the temperature load apply model seems abnormal. What is the reason.
OK, so in that case you need to provide your calculated f1 values in your model instead of 33 degrees which is currently used.
yes correct, now i changed model with temperature load with two cases as T1 and T2.
as soon in below image, pl review
Yes, this looks reasonable.
