Hello I tried importing dxf file in wizard section but still error. What will I do
Please attach the .dxf file
TC.dxfNF7K-FRM_LEG.dxfNF11K-FRM_LEG.dxf
How to use DXF repairing app to repair your DXF file.Click inside the file drop area to upload or drag & drop a file.Your file will be uploaded and we'll show you file's defects with a preview.Select the issues we can fix for you, and click the repair button.
Will
TC1.dxf
Attached TC1.dxf one side of the channel converted to .upt. so no more errors on attached dxf file. Now my problem is, how to create back to back channels using this single channel upt? because the original section has 2 back to back channels. if i use 2 back to back sections in the dxf file, it will give error again, they are not connected to each others. I have the same issue as the attached snap shot from another thread.
Regard,
Bharatha
As Sye mentioned in that other thread, you can add the custom channel into the section database and then use if to create a double channel by using the back to back option in the Section Profile Tables:
Thank you and understand the procedure. so, there is no way to create back to back upt channel?
You can create a General section in the UPT file and provide the sectional properties of this section for the analysis. However, the shape of this section will be shown a single straight line. By the way, such shape should only be analyzed in STAAD.Pro, but not designed as an accurate design of such shapes is not possible in STAAD.Pro.
