Hello I tried importing dxf file in wizard section but still error. What will I do
Thank you and understand the procedure. so, there is no way to create back to back upt channel?
You can create a General section in the UPT file and provide the sectional properties of this section for the analysis. However, the shape of this section will be shown a single straight line. By the way, such shape should only be analyzed in STAAD.Pro, but not designed as an accurate design of such shapes is not possible in STAAD.Pro.
