While design beam RCDC provide min 3 no of bars in the moment area how to bypass this check .There should be option in the RCDC to consider or not to consider this clause ?
if some wants to ignore this particular as many clause staad is ignored or give freedom to user to allow this or not may be helpful
Hi,the guidelines are given in the code for maximum spacing are in view of controlling cracks in the beam. thus, the maximum spacing reduces if we use higher reinforcement grade.We would suggest user to follow the guidelines given in the code.
