Can i extract a beam as whole with nodes in between with openstaad command ? if yes, then how
when extracted it should be in a array
Can you please elaborate your query a little bit more?
i have a single beam consist of multiple nodes in between . So i want to extract all those beam parts divided by nodes as one beam.
Like a physical member whose start node and end node will be there
Can you please reply ?
Can you please create a service ticket for this query?
Service Request Manager
