I am playing around with the RAM Concept API aiming to retrieve PT tendon data and do some post-processing of it. At the moment I have a working script that accesses everything through the following pathway:
model ---> cad_maneger --> tendon_layers --> tendon_segments
This works OK, however when retrieving data for a few hundred tendon segments the processing time increases quite a lot. Is there some way to accelerate this or to bulk-export tendon segment data into some native python data structure that would have quicker handling?
That is the pathway you will need to use to retrieve the tendon segments.
How long is the processing time on your end?
Using the get_tendon_profiles.py script that is saved in "C:\Program Files\Bentley\Engineering\RAM Concept CONNECT Edition\RAM Concept CONNECT Edition V8\python\examples\walkthrough", I am able to extract and output the tendon profile information in a model with nearly 3000 tendon segments with 10 stations per segment in less than 2 minutes.
Answer Verified By: Konstantin Goncharov
Karl,
Thank you for pointing this out - I was not aware that we have example snippets!
I've had a look and get_tendon_profiles.py does seem to run reasonably quickly. I think most of the speed penalty in my script relative to this example comes from the fact that I am reading a lot more data - I am reading start/end coordinates, absolute elevation, soffit elevation, inflection ratio, etc....
Having said that, I do note that the example script makes good use of temporary class variables (location, number, etc). I initially called up all data by burrowing through all class layers (model ---> cad_maneger --> tendon_layers --> tendon_segments --> nodes --> etc) and it appears that doing so carries speed penalty in python. I've re-written with temporary class variables and execution speed for that part of the script improved by approx. 30%.
It is slower than I would prefer, but it seems that this might just be as quick as it will go.
I've marked your response as a verified answer.
