I have a ground floor building, which I want to design in RCDC.
Some of the column sizes required(while designing in RCDC) are reduced, If I extend the column above roof slab (around 1m and categorize this 1m height as gravity column).
What is reason behind this, whether is the right way to design column?
(pic: extra projection of column above roof slab is marked in red)
Regarding this base shear warning: There is no need to increase base shear for industrial structures for seismic loads that defined as per IS 1893 (Part 4):2015 (clause: 9.3 - Notes) right?
If it's - IS 1893 (Part1): 2016, multiplying factor is used.
Dear Sir,
I have limited knowledge of IS 1893 (Part 4):2015. If you have any questions related to RCDC software, please feel free to ask.i would request others to answer this question.
