Instability Joint
1. Staad_19-01-2023 .std
I am not sure what is causing this instability and how to fix this issue. Any advice, suggestions would be appreciated! I have attached the staad model to view. Thank you.
1. Instability at joint 447
2. ***WARNING -  DIAGONAL DECAY AT JOINt 147
3. **WARNING-Tension/Compression did not converge after 10 iterations, Case=    4
Parents Reply Children
